주요 콘텐츠로 건너뛰기
Dell Inspiron 13-7373 Keyboard Replacement
필요한 것
  1. Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Dell Inspiron 13-7373 Keyboard Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Keyboard Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Keyboard Replacement, Fan: 5 단계, 이미지 1개 중 1개
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Keyboard Replacement, Network Card: 7 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Keyboard Replacement, Daughterboard: 8 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Keyboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Keyboard Replacement: 11 단계, 이미지 3개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement: 11 단계, 이미지 3개 중 2개 Dell Inspiron 13-7373 Keyboard Replacement: 11 단계, 이미지 3개 중 3개
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Gently lift up on the motherboard to remove it.
  13. Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: 13 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement, Keyboard: 13 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove the eight 1mm screws at the back of the keyboard.
    • Remove the 3 screws holding the hinges of the laptop on each side.
  14. Dell Inspiron 13-7373 Keyboard Replacement: 14 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement: 14 단계, 이미지 2개 중 2개
    • Lift up on the hinges that the three screws were removed from.
    • They are difficult to move and may require a tad bit more effort.
  15. Dell Inspiron 13-7373 Keyboard Replacement: 15 단계, 이미지 2개 중 1개 Dell Inspiron 13-7373 Keyboard Replacement: 15 단계, 이미지 2개 중 2개
    • Gently remove the keyboard from beneath the hinges that were lifted up.
결론
작성자
2다른 기여자 명과 함께
Kameron Jusseaume
회원 가입일: 10/25/19
492 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G4
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 18
전체 시간: 1,991
