이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
Use an opening tool to remove the bottom half of the case from the laptop.
Use a Phillips screwdriver to remove the four screws holding the battery in place.
Pull the plastic tab on the battery cable to disconnect the cable from the battery.
Unplug the connector holding the fan’s wires.
Remove the fan from the laptop.
Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
Remove the network card from the laptop.
Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
Remove the metal piece holding in the daughterboard.
Disconnect the two cable connectors from the daughterboard.
If the cables are stuck, gently wiggle them until they disconnect.
Release the IO Board Cable.
Release the Touchpad cable.
Release the keyboard back-light cable.
Release the keyboard cable.
Release the eDP cable.
Release the dc-in cable.
Release the cable for the LED charging indicator by gently pulling up on the connector.
다른 한 분이 해당 안내서를 완성하였습니다.
