소개
In this guide, we will show you how to remove and replace the Display Assembly.
필요한 것
Disconnect the display cable and the camera cable from their respective system board connectors.
Remove the six screws (three on each side) that secure the display assembly to the computer base.
Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
Place the NEW display assembly in position and replace the six screws (three on each side) of the display assembly.
Connect the display cable and the camera cable to their respective system board connectors.
다른 2명이 해당 안내서를 완성하였습니다.
