주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 1320 Memory Module Replacement
  1. Dell Inspiron 1320 Memory Module Replacement, Popping up the Memory Module: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  2. Dell Inspiron 1320 Memory Module Replacement, Removing the Memory Module: 2 단계, 이미지 2개 중 1개 Dell Inspiron 1320 Memory Module Replacement, Removing the Memory Module: 2 단계, 이미지 2개 중 2개
    • Remove the memory module from the memory module connector.
  3. Dell Inspiron 1320 Memory Module Replacement, Align the Notch: 3 단계, 이미지 1개 중 1개
    • Align the notch in the NEW memory module with the tab in the memory module connector.
  4. Dell Inspiron 1320 Memory Module Replacement, Sliding the Memory Module: 4 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
결론
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
80,125 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
45 회원들
안내서 2,002개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 49
전체 시간: 298
