소개
In this guide you will be shown in 4 easy steps how to remove and replace the battery in the Dell Inspiron 13z 5323.
필요한 것
Remove nine screws from the bottom case.
The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
Once the captive screw is loosened, remove the small base cover on the bottom of the device.
There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
