주요 콘텐츠로 건너뛰기
Dell Inspiron 13z 5323 Battery Replacement
필요한 것
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 13z 5323 Battery Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 13z 5323 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 13z 5323 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 13z 5323 Battery Replacement: 2 단계, 이미지 3/3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: 3 단계, 이미지 1/3 Dell Inspiron 13z 5323 Battery Replacement: 3 단계, 이미지 2/3 Dell Inspiron 13z 5323 Battery Replacement: 3 단계, 이미지 3/3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: 4 단계, 이미지 1/3 Dell Inspiron 13z 5323 Battery Replacement: 4 단계, 이미지 2/3 Dell Inspiron 13z 5323 Battery Replacement: 4 단계, 이미지 3/3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
결론
Chase Hussey
회원 가입일: 03/08/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 UMass Dartmouth, Team S5-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 21
전체 시간: 876
