주요 콘텐츠로 건너뛰기
Dell Inspiron 13z 5323 Keyboard Replacement
필요한 것
  1. Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • First flip the device over, so the bottom is facing you. Then you will remove the highlighted screw.
  2. Dell Inspiron 13z 5323 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 13z 5323 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 13z 5323 Keyboard Replacement: 2 단계, 이미지 3/3
    • Flip over the laptop and open it so that the screen is facing you.
    • At the top side of the Keyboard closest to the screen you will find 2 inset plastic clips. The clips are shown here in red. Using the flat and of the metal prying tool bend the clips in and at the same time lift the keyboard up.
    • Their is a ribbon connector still attached to the bottom of the keyboard. You should be careful not to damage this cable.
  3. Dell Inspiron 13z 5323 Keyboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron 13z 5323 Keyboard Replacement: 3 단계, 이미지 2/2
    • The ribbon connector seen in yellow can be removed by flipping up the plastic hinge clamp with a thin plastic pry lever
결론
Chase Hussey
회원 가입일: 03/08/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 UMass Dartmouth, Team S5-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 367
