주요 콘텐츠로 건너뛰기
Dell Inspiron 13z 5323 Power button Replacement
필요한 것
  1. Dell Inspiron 13z 5323 Power button Replacement, Power button: 1 단계, 이미지 1/3 Dell Inspiron 13z 5323 Power button Replacement, Power button: 1 단계, 이미지 2/3 Dell Inspiron 13z 5323 Power button Replacement, Power button: 1 단계, 이미지 3/3
    • Remove nine screws from the bottom case.
    • Loosen the single captive screw on the base cover.
    • The screw in the base cover will stay inside the hole because it is held in by a small washer.
  2. Dell Inspiron 13z 5323 Power button Replacement: 2 단계, 이미지 1/3 Dell Inspiron 13z 5323 Power button Replacement: 2 단계, 이미지 2/3 Dell Inspiron 13z 5323 Power button Replacement: 2 단계, 이미지 3/3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a small flathead screwdriver to push the tabs so the keyboard will pop out.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Power button Replacement: 3 단계, 이미지 1/3 Dell Inspiron 13z 5323 Power button Replacement: 3 단계, 이미지 2/3 Dell Inspiron 13z 5323 Power button Replacement: 3 단계, 이미지 3/3
    • Unscrew the highlighted screw and slide out the power button assembly.
    • Separate the palm rest from the base of the device using the blue separating tool. Before separating the palm rest from the device make sure to release all visible ribbon connectors.
    • Flip the palm rest over and you will notice the power button assembly in the top right corner of the palm rest.
결론
David Gilleran
회원 가입일: 03/08/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S5-G6, Botvin Spring 2017 UMass Dartmouth, Team S5-G6, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G6
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
this guide has no descriptions on what is going feels incomplete.
Matthew Coughlin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 246
