주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3459 Memory Modules Replacement
  1. Dell Inspiron 14 3459 Memory Modules Replacement, Popping up the Memory Module: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 14 3459 Memory Modules Replacement, Removing the Memory Module: 2 단계, 이미지 1개 중 1개
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 14 3459 Memory Modules Replacement, Align the Notch: 3 단계, 이미지 1개 중 1개
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  4. Dell Inspiron 14 3459 Memory Modules Replacement, Sliding the Memory Module: 4 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 321
