주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3462 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: 1 단계, 이미지 1개 중 1개
  2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: 2 단계, 이미지 1개 중 1개
    • Open the latch that secures the display cable into position.
    • Disconnect the display cable from the system board.
  3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: 3 단계, 이미지 1개 중 1개
    • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
  4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: 4 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display at an angle of 90 degrees.
    • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
  5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
  6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: 6 단계, 이미지 1개 중 1개
    • Carefully lift the display assembly from the palm-rest assembly.
  7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Carefully place the display assembly on a clean and flat surface.
  8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: 8 단계, 이미지 1개 중 1개
    • Place the NEW display assembly at the edge of the table.
  9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: 9 단계, 이미지 1개 중 1개
    • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
  10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: 10 단계, 이미지 1개 중 1개
    • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: 11 단계, 이미지 1개 중 1개
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: 12 단계, 이미지 1개 중 1개
    • Connect the display cable from the system board.
  13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: 13 단계, 이미지 1개 중 1개
    • Close the latch that secures the display cable to the system board.
  14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: 14 단계, 이미지 1개 중 1개
    • Adhere the tape that secures the display cable to the system board.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 261
