주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3462 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14 3462 Hard Drive Replacement, Disconnecting the Hard Drive Cable: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Open the latch, and disconnect the hard-drive cable from the connector on the system board.
  2. Dell Inspiron 14 3462 Hard Drive Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  3. Dell Inspiron 14 3462 Hard Drive Replacement, Removing the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly along with its cable off the palm-rest assembly.
  4. Dell Inspiron 14 3462 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 2개 중 1개 Dell Inspiron 14 3462 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 2개 중 2개
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard-drive assembly.
  5. Dell Inspiron 14 3462 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 5 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly off the hard-drive bracket.
  6. Dell Inspiron 14 3462 Hard Drive Replacement, Disconnecting the Interposer: 6 단계, 이미지 1개 중 1개
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3462 Hard Drive Replacement, Connect the Interposer: 7 단계, 이미지 1개 중 1개
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3462 Hard Drive Replacement, Align the Screw Holes: 8 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard-drive assembly.
  9. Dell Inspiron 14 3462 Hard Drive Replacement, Replace the Screws: 9 단계, 이미지 2개 중 1개 Dell Inspiron 14 3462 Hard Drive Replacement, Replace the Screws: 9 단계, 이미지 2개 중 2개
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard-drive assembly.
  10. Dell Inspiron 14 3462 Hard Drive Replacement, Align the Screw Holes: 10 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  11. Dell Inspiron 14 3462 Hard Drive Replacement, Replace the Screws: 11 단계, 이미지 1개 중 1개
    • Replace the two screws (M2x3) that secure the hard-drive assembly to the palm-rest assembly.
  12. Dell Inspiron 14 3462 Hard Drive Replacement, Slide the Hard-Drive Cable: 12 단계, 이미지 1개 중 1개
    • Slide the hard-drive cable into the connector on the system board and press down the latch to secure the cable.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 10
전체 시간: 612
