주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3465 Base Cover Replacement
필요한 것
  1. Dell Inspiron 14 3465 Base Cover Replacement, Turning The Computer Over: 1 단계, 이미지 1개 중 1개
    • Close the display, and turn the computer over.
  2. Dell Inspiron 14 3465 Base Cover Replacement, Removing Eight Screws: 2 단계, 이미지 1개 중 1개
    • Remove the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3465 Base Cover Replacement, Removing Two Screws: 3 단계, 이미지 1개 중 1개
    • Remove the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3465 Base Cover Replacement, Rmoving Three Screws: 4 단계, 이미지 1개 중 1개
    • Remove the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3465 Base Cover Replacement, Open The Display: 5 단계, 이미지 1개 중 1개
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3465 Base Cover Replacement, Removing Three Screws: 6 단계, 이미지 1개 중 1개
    • Remove the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  7. Dell Inspiron 14 3465 Base Cover Replacement, Disconneting The Optical-Drive Cable: 7 단계, 이미지 1개 중 1개
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: 8 단계, 이미지 1개 중 1개
  9. Dell Inspiron 14 3465 Base Cover Replacement, Prying The Base Cover: 9 단계, 이미지 1개 중 1개
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3465 Base Cover Replacement, Lifting The Base Cover: 10 단계, 이미지 1개 중 1개
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3465 Base Cover Replacement, Releasing the optical-drive: 11 단계, 이미지 1개 중 1개
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3465 Base Cover Replacement, Sliding the optical-drive: 12 단계, 이미지 1개 중 1개
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3465 Base Cover Replacement, Placing The New Base Cover: 13 단계, 이미지 1개 중 1개
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Tabs: 14 단계, 이미지 1개 중 1개
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3465 Base Cover Replacement, Sliding The Optical-Drive Cable: 15 단계, 이미지 1개 중 1개
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: 16 단계, 이미지 1개 중 1개
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3465 Base Cover Replacement, Turn Over The Computer: 17 단계, 이미지 1개 중 1개
  18. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Three Screws: 18 단계, 이미지 1개 중 1개
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Two Screws: 19 단계, 이미지 1개 중 1개
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3465 Base Cover Replacement, Replacing The Eight Screws: 20 단계, 이미지 1개 중 1개
    • Replace the eight screws (M2.5x8) that secure the base cover to the palm-rest assembly
결론
작성자
1다른 기여자 명과 함께
darrius
회원 가입일: 03/26/18
5,213 평판
안내서 30개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 8
전체 시간: 178
