주요 콘텐츠로 건너뛰기
Dell Inspiron 14 3465 Battery Replacement
필요한 것
  1. Dell Inspiron 14 3465 Battery Replacement, Unlocking the Battery: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Turn the computer over and slide the battery latch to the unlock position. You can hear a click sound when the battery is unlocked.
  2. Dell Inspiron 14 3465 Battery Replacement, Removing the Battery: 2 단계, 이미지 1개 중 1개
    • Using your fingertips, lift the battery at an angle and remove the battery off the computer base.
  3. Dell Inspiron 14 3465 Battery Replacement, Grounding the System Board: 3 단계, 이미지 1개 중 1개
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 3465 Battery Replacement, Installing the Battery: 4 단계, 이미지 1개 중 1개
    • Slide the tabs on the NEW battery into the slots on the battery bay and snap the battery into place.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 111
