소개
How To Remove And Replace The Memory Module
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the NEW memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
다른 한 분이 해당 안내서를 완성하였습니다.
