주요 콘텐츠로 건너뛰기
Dell Inspiron 14 5100 Fan Replacement
필요한 것
  1. Dell Inspiron 14 5100 Fan Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 1/3 Dell Inspiron 14 5100 Fan Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 2/3 Dell Inspiron 14 5100 Fan Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 3/3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14 5100 Fan Replacement: 2 단계, 이미지 2/2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Remove the two Phillips #0 screws securing the fan to the keyboard assembly.
  4. Dell Inspiron 14 5100 Fan Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14 5100 Fan Replacement: 4 단계, 이미지 2/2
    • Remove the tape securing the fan cable to the motherboard.
  5. Dell Inspiron 14 5100 Fan Replacement: 5 단계, 이미지 1/1
    • Lift the fan and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ting-Hao Lao
회원 가입일: 09/17/19
588 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 716
