주요 콘텐츠로 건너뛰기
Dell Inspiron 14 5100 Motherboard Replacement
필요한 것
  1. Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 1/3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 2/3 Dell Inspiron 14 5100 Motherboard Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 3/3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Motherboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 2 단계, 이미지 2/2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Motherboard Replacement, RAM: 3 단계, 이미지 1/1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 Motherboard Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
  6. Dell Inspiron 14 5100 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Detach the white connector from the motherboard using the spudger.
  7. Dell Inspiron 14 5100 Motherboard Replacement: 7 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 7 단계, 이미지 2/2
    • Flip up the retaining flap and remove the blue ribbon cable from its connector on the motherboard using a spudger.
  8. Dell Inspiron 14 5100 Motherboard Replacement: 8 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 8 단계, 이미지 2/2
    • Flip up the retaining flap and remove the orange ribbon cable from its connector on the motherboard using a spudger.
  9. Dell Inspiron 14 5100 Motherboard Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 9 단계, 이미지 2/2
    • Detach the CMOS battery connector using the spudger.
  10. Dell Inspiron 14 5100 Motherboard Replacement: 10 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the black connector using the spudger.
  11. Dell Inspiron 14 5100 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the single 3 mm screw from the Wi-Fi card using the Phillips #0 screwdriver.
    • Pull the Wi-Fi card out of the slot and set aside.
  12. Dell Inspiron 14 5100 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the single screw from the SSD using the Phillips #0 screwdriver.
    • Remove the SSD from the motherboard.
  13. Dell Inspiron 14 5100 Motherboard Replacement: 13 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 13 단계, 이미지 2/2
    • Remove two 2 mm screws using the Phillips #0 screwdriver.
  14. Dell Inspiron 14 5100 Motherboard Replacement: 14 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 14 단계, 이미지 2/2
    • Disconnect the cable from its connector on the motherboard using the spudger.
  15. Dell Inspiron 14 5100 Motherboard Replacement: 15 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 15 단계, 이미지 2/2
    • Lift the metal retaining flap using the opening tool.
    • Remove the connector from the bracket.
  16. Dell Inspiron 14 5100 Motherboard Replacement: 16 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 16 단계, 이미지 2/2
    • Detach the cable using the spudger.
  17. Dell Inspiron 14 5100 Motherboard Replacement: 17 단계, 이미지 1/2 Dell Inspiron 14 5100 Motherboard Replacement: 17 단계, 이미지 2/2
    • Detach the connector using the spudger.
  18. Dell Inspiron 14 5100 Motherboard Replacement: 18 단계, 이미지 1/1
    • Remove six 3 mm screws using the Phillips #0 screwdriver.
  19. Dell Inspiron 14 5100 Motherboard Replacement: 19 단계, 이미지 1/1
    • Remove the motherboard by lifting it from the rear and then completely removing it from the laptop.
결론
Meth Ranaweera
회원 가입일: 09/20/21
436 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 673
