주요 콘텐츠로 건너뛰기
Dell Inspiron 14 5100 RAM Replacement
필요한 것
  1. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 1/3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 2/3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 3/3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 RAM Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14 5100 RAM Replacement: 2 단계, 이미지 2/2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 RAM Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14 5100 RAM Replacement: 4 단계, 이미지 2/2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 RAM Replacement: 5 단계, 이미지 1/1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Meth Ranaweera
회원 가입일: 09/20/21
436 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 71
전체 시간: 1,195
