주요 콘텐츠로 건너뛰기
Dell Inspiron 14 5100 Touch Pad Replacement
필요한 것
  1. Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 1/3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 2/3 Dell Inspiron 14 5100 Touch Pad Replacement, Dell Inspiron 14 5100 Disassembly: 1 단계, 이미지 3/3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 Touch Pad Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14 5100 Touch Pad Replacement: 2 단계, 이미지 2/2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 Touch Pad Replacement, Battery: 3 단계, 이미지 1/2 Dell Inspiron 14 5100 Touch Pad Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the four Phillips #0 screws securing the battery to the keyboard assembly.
  4. Dell Inspiron 14 5100 Touch Pad Replacement: 4 단계, 이미지 1/3 Dell Inspiron 14 5100 Touch Pad Replacement: 4 단계, 이미지 2/3 Dell Inspiron 14 5100 Touch Pad Replacement: 4 단계, 이미지 3/3
    • Peel off the tape securing the battery cable to the battery cable connector.
    • Disconnect and remove the old battery.
  5. Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 5 단계, 이미지 1/3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 5 단계, 이미지 2/3 Dell Inspiron 14 5100 Touch Pad Replacement, Touch Pad: 5 단계, 이미지 3/3
    • Disconnect the touchpad cable attached to the motherboard.
    • Be careful lifting the Flat Flex Cable (FFC) connector as it is quite fragile.
  6. Dell Inspiron 14 5100 Touch Pad Replacement: 6 단계, 이미지 1/2 Dell Inspiron 14 5100 Touch Pad Replacement: 6 단계, 이미지 2/2
    • Peel off the tapes securing the touchpad to the keyboard assembly.
  7. Dell Inspiron 14 5100 Touch Pad Replacement: 7 단계, 이미지 1/1
    • Remove the four screws securing the touchpad to the keyboard assembly using the Phillips #0 screwdriver.
  8. Dell Inspiron 14 5100 Touch Pad Replacement: 8 단계, 이미지 1/3 Dell Inspiron 14 5100 Touch Pad Replacement: 8 단계, 이미지 2/3 Dell Inspiron 14 5100 Touch Pad Replacement: 8 단계, 이미지 3/3
    • Remove the three screws securing the touchpad bracket to the keyboard assembly using the Phillips #0 screwdriver.
    • Lift the touchpad bracket.
  9. Dell Inspiron 14 5100 Touch Pad Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14 5100 Touch Pad Replacement: 9 단계, 이미지 2/2
    • Lif tthe touchpad and replace with the new touchpad.
    • Make sure to guide the touchpad cable along with the touchpad to avoid damaging the parts.
    • Lift the touchpad at an angle from under the touchpad bracket to avoid damaging the touchpad or the touchpad bracket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonn Ross Olofernes
회원 가입일: 09/24/19
217 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,055
