주요 콘텐츠로 건너뛰기
Dell Inspiron 14 7447 Battery Replacement
  1. Dell Inspiron 14 7447 Battery Replacement, Sliding the Release Latches: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Slide the battery-release latches to the unlock position.
  2. Dell Inspiron 14 7447 Battery Replacement, Lifting the Battery: 2 단계, 이미지 2개 중 1개 Dell Inspiron 14 7447 Battery Replacement, Lifting the Battery: 2 단계, 이미지 2개 중 2개
    • Using your fingertips, lift the battery at an angle and remove the battery off the computer base.
  3. Dell Inspiron 14 7447 Battery Replacement, Grounding the System Board: 3 단계, 이미지 1개 중 1개
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
  4. Dell Inspiron 14 7447 Battery Replacement, Inserting the Battery: 4 단계, 이미지 1개 중 1개
    • Insert the NEW battery at an angle into the battery bay and align the tabs on the battery with the slots on the battery bay.
  5. Dell Inspiron 14 7447 Battery Replacement, Press the Battery Down: 5 단계, 이미지 1개 중 1개
    • Press the battery down until it snaps into place.
  6. Dell Inspiron 14 7447 Battery Replacement, Opening the Display: 6 단계, 이미지 1개 중 1개
    • Turn the computer over and open the display as far as possible.
결론
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 1,060
