주요 콘텐츠로 건너뛰기
Dell Inspiron 14 M4010 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron 14 M4010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: 2 단계, 이미지 1개 중 1개
    • Slide the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly away from the system board.
  4. Dell Inspiron 14 M4010 Hard Drive Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 M4010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 5 단계, 이미지 1개 중 1개
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 M4010 Hard Drive Replacement, Align the Screws: 6 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
  7. Dell Inspiron 14 M4010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: 7 단계, 이미지 1개 중 1개
    • Slide and push the hard-drive assembly to connect it to connector on the system board.
  8. Dell Inspiron 14 M4010 Hard Drive Replacement, Replace the Screws: 8 단계, 이미지 1개 중 1개
    • Replace the two screws that secure the hard-drive assembly to the system board.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 134
