주요 콘텐츠로 건너뛰기
Dell Inspiron 14 N4050 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14 N4050 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 2 단계, 이미지 1/1
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 N4050 Hard Drive Replacement, Remove the Screws: 3 단계, 이미지 1/1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 4 단계, 이미지 1/1
    • Lift the hard-drive bracket away from the hard drive.
  5. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Bracket: 5 단계, 이미지 1/1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 N4050 Hard Drive Replacement, Replace the Screws: 6 단계, 이미지 1/1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Assembly: 7 단계, 이미지 1/1
    • Place the hard-drive assembly on the computer base.
  8. Dell Inspiron 14 N4050 Hard Drive Replacement, Push the Hard Drive Assembly: 8 단계, 이미지 1/1
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
결승점
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,597
