주요 콘텐츠로 건너뛰기
Dell Inspiron 14-5447 Battery Replacement
필요한 것
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14-5447 Battery Replacement: 2 단계, 이미지 2/2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 14-5447 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14-5447 Battery Replacement: 4 단계, 이미지 2/2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Isabella Chavez
회원 가입일: 04/11/17
476 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 23
전체 시간: 3,080
