주요 콘텐츠로 건너뛰기
Dell Inspiron 14-5447 Fan Replacement
필요한 것
  1. Dell Inspiron 14-5447 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Fan Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 2 단계, 이미지 2/2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Fan Replacement: 3 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Fan Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 4 단계, 이미지 2/2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Fan Replacement, Fan: 5 단계, 이미지 1/1
    • Locate the fan system in the top right corner.
  6. Dell Inspiron 14-5447 Fan Replacement: 6 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 6 단계, 이미지 2/2
    • Look along the wide line of white cable until you find the tab insert.
    • Remove the thick white cable crossing over the fan, using the blue spudger shown, to flip the securing flap holding down the cable.
  7. Dell Inspiron 14-5447 Fan Replacement: 7 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 7 단계, 이미지 2/2
    • Move the cable over to the side to reveal the fan screws.
    • Remove the two black 5.70 mm screws from the fan.
  8. Dell Inspiron 14-5447 Fan Replacement: 8 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the small cable attached to the fan.
  9. Dell Inspiron 14-5447 Fan Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14-5447 Fan Replacement: 9 단계, 이미지 2/2
    • Using the opening tool, pry the fan out.
    • Remove the fan slowly to prevent damage to any wires or cables connected to the device.
  10. Dell Inspiron 14-5447 Fan Replacement: 10 단계, 이미지 1/1
    • Now that the fan is removed, be sure to clean the area under the fan to prevent overheating.
결론
Isabella Chavez
회원 가입일: 04/11/17
476 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 839
