주요 콘텐츠로 건너뛰기
Dell Inspiron 14-5447 Wi-Fi Card Replacement
필요한 것
  1. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 1/2 Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Locate the Wifi card on the top left of the laptop.
    • Use the tweezers to release the black and white cables.
  6. Dell Inspiron 14-5447 Wi-Fi Card Replacement: 6 단계, 이미지 1/1
    • Remove one silver 2.9mm Phillips #1 screw which secures the WiFi card.
  7. Dell Inspiron 14-5447 Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • The Wi-Fi card should slide out of the black socket.
    • Use tweezers to push the white part of the Wi-Fi card up towards the top of the device to remove.
    • Remove the card with the tweezers.
결론
Isabella Chavez
회원 가입일: 04/11/17
476 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 23
전체 시간: 1,268
