소개
The Lithium-Polymer Battery in this laptop is long lasting but if it were to stop holding a charge then replacing it is simple and fast.
필요한 것
Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
