주요 콘텐츠로 건너뛰기
Dell Inspiron 14-7437 Coin Cell Battery Replacement
필요한 것
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 1 단계, 이미지 1/2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 1 단계, 이미지 2/2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 2 단계, 이미지 2/2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 3 단계, 이미지 1/2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 5 단계, 이미지 1/1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: 6 단계, 이미지 1/1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 7 단계, 이미지 1/3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 7 단계, 이미지 2/3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 7 단계, 이미지 3/3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: 8 단계, 이미지 1/1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 9 단계, 이미지 2/2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katelyn Remy
회원 가입일: 03/10/16
449 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S7G8
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 19
전체 시간: 1,322
