주요 콘텐츠로 건너뛰기
Dell Inspiron 1420 Display Replacement
필요한 것
  1. Dell Inspiron 1420 Display Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, Battery: 1 단계, 이미지 3/3
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 2 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 2 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 2 단계, 이미지 3/3
    • Use a spudger to pry the 6 rubber bumpers from the display.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
  3. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 3 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 3 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: 3 단계, 이미지 3/3
    • Gently pry the frame using a spudger.
    • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
  4. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: 4 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: 4 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: 4 단계, 이미지 3/3
    • Use a spudger to loosen the frame from the top.
    • Lift up the black connector to detach the gold ribbon.
  5. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: 5 단계, 이미지 1/2 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: 5 단계, 이미지 2/2
    • Pull directly up on the light blue tab.
  6. Dell Inspiron 1420 Display Replacement, VGA cable: 6 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, VGA cable: 6 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, VGA cable: 6 단계, 이미지 3/3
    • Squeeze the two metal clips located on the VGA cable.
    • Pull while squeezing the clips in order to remove the cable.
  7. Dell Inspiron 1420 Display Replacement, Isolating the Display: 7 단계, 이미지 1/3 Dell Inspiron 1420 Display Replacement, Isolating the Display: 7 단계, 이미지 2/3 Dell Inspiron 1420 Display Replacement, Isolating the Display: 7 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
    • Remove the metal brackets, one on each side, by gently pulling.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kris Karanxha
회원 가입일: 09/23/14
298 평판
안내서 1개 작성함
USF Tampa, Team 2-4, Blackwell Fall 2014 USF Tampa, Team 2-4, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S2G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,446
