소개
This guide is to replace a broken or faulty keyboard on the Insprion 1420 laptop.
필요한 것
Using a spudger, pry off the top cover plate, thus exposing the screws for the keyboard.
Using a Phillips #00 screwdriver, unscrew the two 3mm screws holding the keyboard down.
Using a spudger, carefully lift the blue tab, releasing the ribbon connector and freeing the keyboard to be removed.
다른 3명이 해당 안내서를 완성하였습니다.
