소개
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
Disconnect the display cable from the connector on the system board.
Remove the four screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Route the display cable and Mini-Card antenna cables through the routing guides.
Connect the display cable to the connector on the system board.
거의 끝나갑니다!
결승점
