주요 콘텐츠로 건너뛰기
Dell Inspiron 1425 Memory Modules Replacement
  1. Dell Inspiron 1425 Memory Modules Replacement, Popping up the Memory Module: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron 1425 Memory Modules Replacement, Removing the Memory Modules: 2 단계, 이미지 1/1
    • Remove the memory module(s) from the memory-module connector.
  3. Dell Inspiron 1425 Memory Modules Replacement, Align the Notch: 3 단계, 이미지 1/1
    • Align the notch in the memory module with the tab in the memory-module connector.
  4. Dell Inspiron 1425 Memory Modules Replacement, Installing the Memory Module: 4 단계, 이미지 1/1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
결승점
Terrence15
회원 가입일: 12/18/17
79,243 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 93
