주요 콘텐츠로 건너뛰기
Dell Inspiron 1440 Touch Pad Buttons Replacement
필요한 것
  1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: 1 단계, 이미지 1/2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: 1 단계, 이미지 2/2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Touch Pad Buttons Replacement: 2 단계, 이미지 1/1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Touch Pad Buttons Replacement: 3 단계, 이미지 1/1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: 4 단계, 이미지 1/2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: 4 단계, 이미지 2/2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that surrounding and underneath a middle plate.
  5. Dell Inspiron 1440 Touch Pad Buttons Replacement: 5 단계, 이미지 1/2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 5 단계, 이미지 2/2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard.
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Touch Pad Buttons Replacement: 6 단계, 이미지 1/2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 6 단계, 이미지 2/2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Touch Pad Buttons Replacement: 7 단계, 이미지 1/2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 7 단계, 이미지 2/2
    • Flip over the silver plate, and remove the 3 mm screw attached the buttons.
    • Remove the ribbon cables that are also attached.
  8. Dell Inspiron 1440 Touch Pad Buttons Replacement: 8 단계, 이미지 1/1
    • Remove the buttons.
결론
Tyler Lyons
회원 가입일: 11/05/19
452 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 UMass Dartmouth, Team S1-G3, Barthe Fall 2019 회원
UMASSD-BARTHE-F19S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 363
