주요 콘텐츠로 건너뛰기
Dell Inspiron 14R Memory Modules Replacement
  1. Dell Inspiron 14R Memory Modules Replacement, Popping up the Memory Module: 1 단계, 이미지 1개 중 1개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron 14R Memory Modules Replacement, Remove the Memory Module: 2 단계, 이미지 1개 중 1개
    • Remove the memory module(s) from the memory-module connector.
  3. Dell Inspiron 14R Memory Modules Replacement, Align the Notch: 3 단계, 이미지 1개 중 1개
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron 14R Memory Modules Replacement, Sliding the Memory Module: 4 단계, 이미지 1개 중 1개
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,675 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,991개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 150
