소개
In this guide, we will be showing you how to remove and replace the Hard Drive.
필요한 것
Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
Remove the screws that secure the hard-drive assembly to the computer base.
Make a note of the hard-drive cable routing and remove the cable from the routing guides.
Lift the hard-drive assembly along with its cable away from the computer base.
Pull the interposer to disconnect the hard-drive cable from the hard-drive.
Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
Place the hard-drive assembly in the hard-drive bay on the computer base.
Replace the screws that secure the hard-drive assembly to the computer base.
Route the hard-drive cable through the routing guides on the computer base.
Connect the hard-drive cable to the system-board connector.
