주요 콘텐츠로 건너뛰기
Dell Inspiron 14R-5421 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 14R-5421 Hard Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Hard Drive  Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14R-5421 Hard Drive  Replacement: 2 단계, 이미지 2/2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Hard Drive  Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Start by removing the cover that hides all the internal components by sliding it in the direction shown
  4. Dell Inspiron 14R-5421 Hard Drive  Replacement: 4 단계, 이미지 1/1
    • Now, remove the single screw that is securing the hard drive to the laptop noted by the red circle.
  5. Dell Inspiron 14R-5421 Hard Drive  Replacement: 5 단계, 이미지 1/1
    • Now carefully lift then pull the hard drive out to the left until it detaches
결론
Jared paiva
회원 가입일: 03/27/18
489 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S4-G4, Covino Spring 2018 UMass Dartmouth, Team S4-G4, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 25
전체 시간: 562
