주요 콘텐츠로 건너뛰기
Dell Inspiron 14R-5421 Keyboard Replacement
필요한 것
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Inspiron 14R-5421 Keyboard Replacement: 2 단계, 이미지 2/2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: 4 단계, 이미지 1/1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: 5 단계, 이미지 1/1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
결론
Jared paiva
회원 가입일: 03/27/18
489 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S4-G4, Covino Spring 2018 UMass Dartmouth, Team S4-G4, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 539
