소개
In this guide, we will be showing you how to remove and replace the Display Assembly.
필요한 것
Remove the two screws that secure the display assembly to the computer base.
Lift the connector latch and disconnect the display cable from the connector on the system board.
Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
Route the display, camera, and mini-card antenna cables through their routing guides.
Slide the display cable in the connector on the system board and press down the latch to secure the cable.
Turn the computer over.
Replace the two screws that secure the display assembly to the computer base.
