주요 콘텐츠로 건너뛰기
Dell Inspiron 14z N114z Speaker Replacement
필요한 것
  1. Dell Inspiron 14z N114z Speaker Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 14z N114z Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumbs, push out on both side tabs simultaneously. You should hear a soft click and see the battery slightly pop out.
    • Grab and lift the battery off from the underside of the laptop.
  2. Dell Inspiron 14z N114z Speaker Replacement, Top Panel: 2 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement, Top Panel: 2 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement, Top Panel: 2 단계, 이미지 3/3
    • Unscrew one 6.75mm screw on the bottom of the plate using a PH0 tip.
    • Lift off the back plate and set aside
  3. Dell Inspiron 14z N114z Speaker Replacement: 3 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 3 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 3 단계, 이미지 3/3
    • Unscrew four 3.85mm screws holding the hard-drive in place using the ph0 tip.
    • Slide hard drive to the left and gently lift off.
  4. Dell Inspiron 14z N114z Speaker Replacement: 4 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 4 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 4 단계, 이미지 3/3
    • Unscrew one 3.85mm screw using the PH0 tip and remove from the disk drive.
  5. Dell Inspiron 14z N114z Speaker Replacement: 5 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 5 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 5 단계, 이미지 3/3
    • Unscrew seven 5.70mm screws using the PH0 tip.
    • Unscrew six 3.85mm screws using the PH0 tip.
  6. Dell Inspiron 14z N114z Speaker Replacement: 6 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 6 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 6 단계, 이미지 3/3
    • careful lifting up on the key board once free there is ribbon connected to the bottom.
    • Carefully flip laptop right side up and open to view the keyboard.
    • Using a plastic opening tool, pry up on the four tabs holding the keyboard in place. Be careful not to damage the keys on the top of the keyboard. You will know when it has been successfully pried open when you hear four clicks from the top of keyboard.
    • Gently lift the keyboard out from the rest of the laptop and immediately flip over without damaging the ribbon cable.
    • Carefully disconnect the ribbon cable by flipping up the tab holding the cable in place by using a plastic opening tool. Set keyboard and ribbon cable aside.
  7. Dell Inspiron 14z N114z Speaker Replacement: 7 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 7 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 7 단계, 이미지 3/3
    • Remove the seven 5.70 mm screws using the PH0 bit.
    • Remove the three ribbon cables by using the plastic opening tool to release the latch holding the cable.
  8. Dell Inspiron 14z N114z Speaker Replacement: 8 단계, 이미지 1/2 Dell Inspiron 14z N114z Speaker Replacement: 8 단계, 이미지 2/2
    • Pry up on the edge of the seam of the laptop using the plastic opening tool. Continue prying around the entire outside of the laptop until you feel separation.
    • Pull the top portion off.
  9. Dell Inspiron 14z N114z Speaker Replacement, Speaker: 9 단계, 이미지 1/2 Dell Inspiron 14z N114z Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Remove the fan using the PH0 tip and remove the one 3.85mm screw.
    • Disconnect the cable connector.
  10. Dell Inspiron 14z N114z Speaker Replacement: 10 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 10 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 10 단계, 이미지 3/3
    • Remove the two ribons using the plastic opening tool.
    • Remove the cable connector.
  11. Dell Inspiron 14z N114z Speaker Replacement: 11 단계, 이미지 1/2 Dell Inspiron 14z N114z Speaker Replacement: 11 단계, 이미지 2/2
    • Remove the ribbon connector using the plastic opening tool.
    • Remove the cable connector using the plastic opening tool.
  12. Dell Inspiron 14z N114z Speaker Replacement: 12 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 12 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 12 단계, 이미지 3/3
    • Remove the one 3.85mm screw and remove the WLAN chip.
  13. Dell Inspiron 14z N114z Speaker Replacement: 13 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 13 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 13 단계, 이미지 3/3
    • Pry up on the back side of the laptop seam until you hear the clicking.
    • Remove the two screws that hold the screen on using the PH0 tip, then pull up on screen.
  14. Dell Inspiron 14z N114z Speaker Replacement: 14 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 14 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 14 단계, 이미지 3/3
    • Remove four 3.85 mm screws from the mother board.
    • Remove the four 5.65mm screws from the mother board using the ph0 tip.
    • Lift up on the mother board to remove it.
  15. Dell Inspiron 14z N114z Speaker Replacement: 15 단계, 이미지 1/2 Dell Inspiron 14z N114z Speaker Replacement: 15 단계, 이미지 2/2
    • Remove the two 3.85 screws from the photo chip reader using the ph0 tip.
    • Lift up on the card reader to remove.
  16. Dell Inspiron 14z N114z Speaker Replacement: 16 단계, 이미지 1/3 Dell Inspiron 14z N114z Speaker Replacement: 16 단계, 이미지 2/3 Dell Inspiron 14z N114z Speaker Replacement: 16 단계, 이미지 3/3
    • Remove one 3.60mm screw using the ph0 tip from each speaker then lift both up.
결론
Duggan Young
회원 가입일: 01/19/17
601 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 195
