주요 콘텐츠로 건너뛰기
Dell Inspiron 14z-5423 Battery Replacement
필요한 것
  1. Dell Inspiron 14z-5423 Battery Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement, RAM: 1 단계, 이미지 2/2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Battery Replacement: 2 단계, 이미지 1/1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 3 단계, 이미지 2/2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 4 단계, 이미지 2/2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Battery Replacement: 5 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Battery Replacement, Optical Drive: 6 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement, Optical Drive: 6 단계, 이미지 2/2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Battery Replacement, Keyboard: 7 단계, 이미지 1/3 Dell Inspiron 14z-5423 Battery Replacement, Keyboard: 7 단계, 이미지 2/3 Dell Inspiron 14z-5423 Battery Replacement, Keyboard: 7 단계, 이미지 3/3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Battery Replacement: 8 단계, 이미지 1/1
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Battery Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 9 단계, 이미지 2/2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Battery Replacement: 10 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 10 단계, 이미지 2/2
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Battery Replacement: 11 단계, 이미지 1/3 Dell Inspiron 14z-5423 Battery Replacement: 11 단계, 이미지 2/3 Dell Inspiron 14z-5423 Battery Replacement: 11 단계, 이미지 3/3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Battery Replacement, Palm Rest Assembly: 12 단계, 이미지 1/1
  13. Dell Inspiron 14z-5423 Battery Replacement: 13 단계, 이미지 1/3 Dell Inspiron 14z-5423 Battery Replacement: 13 단계, 이미지 2/3 Dell Inspiron 14z-5423 Battery Replacement: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Battery Replacement: 14 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement: 14 단계, 이미지 2/2
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Battery Replacement: 15 단계, 이미지 1/1
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Battery Replacement: 16 단계, 이미지 1/3 Dell Inspiron 14z-5423 Battery Replacement: 16 단계, 이미지 2/3 Dell Inspiron 14z-5423 Battery Replacement: 16 단계, 이미지 3/3
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Battery Replacement, Battery: 17 단계, 이미지 1/2 Dell Inspiron 14z-5423 Battery Replacement, Battery: 17 단계, 이미지 2/2
    • Use a J0 Bit screwdriver to remove the two 6 mm Phillips screws securing the battery located near the bottom of the laptop.
  18. Dell Inspiron 14z-5423 Battery Replacement: 18 단계, 이미지 1/3 Dell Inspiron 14z-5423 Battery Replacement: 18 단계, 이미지 2/3 Dell Inspiron 14z-5423 Battery Replacement: 18 단계, 이미지 3/3
    • Lift the tiny black tab and pull the battery out at a slight angle.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Brittany
회원 가입일: 09/12/16
914 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G2
5 회원들
안내서 11개 작성하였습니다
댓글 한 개
Thanks! These instructions worked very well for me, and I performed my battery and disk upgrades successfully!
ericfogleman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 30
전체 시간: 5,533
