주요 콘텐츠로 건너뛰기
Dell Inspiron 14z-5423 Keyboard Replacement
필요한 것
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: 1 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: 1 단계, 이미지 2/2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: 2 단계, 이미지 1/1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: 3 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement: 3 단계, 이미지 2/2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: 4 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement: 4 단계, 이미지 2/2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 6 단계, 이미지 1/3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 6 단계, 이미지 2/3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 6 단계, 이미지 3/3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: 7 단계, 이미지 1/1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: 8 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement: 8 단계, 이미지 2/2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: 9 단계, 이미지 1/2 Dell Inspiron 14z-5423 Keyboard Replacement: 9 단계, 이미지 2/2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: 10 단계, 이미지 1/3 Dell Inspiron 14z-5423 Keyboard Replacement: 10 단계, 이미지 2/3 Dell Inspiron 14z-5423 Keyboard Replacement: 10 단계, 이미지 3/3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marisol
회원 가입일: 09/12/16
623 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G2
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 19
전체 시간: 1,498
