주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3541 Battery Replacement
  1. Dell Inspiron 15 3541 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Allison
회원 가입일: 03/04/16
571 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개를 작성함
댓글 2개
Can you do a guide on how to change a CPU on this computer?
F0RS3 Topaz - 답글
During this, the locks in side of this gets dispalced from there places so battery is not locking now. How to repair those locks?.
Vivek Goyenka - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 19
전체 시간: 1,871
