주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 15 3541 Keyboard Replacement
필요한 것
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 3541 Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Allison
회원 가입일: 03/04/16
598 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G8
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 58
전체 시간: 3,851
