주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3567 Battery Replacement
  1. Dell Inspiron 15 3567 Battery Replacement, Sliding the Battery Latch: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Slide the battery-release latch to the unlocked position.
    • You hear a click sound when the battery is unlocked.
  2. Dell Inspiron 15 3567 Battery Replacement, Lifting the Battery: 2 단계, 이미지 1/1
    • Using your fingertips, lift the battery at an angle and remove it from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  3. Dell Inspiron 15 3567 Battery Replacement, Placing the Battery: 5 단계, 이미지 1/1
    • Place the battery in the battery bay and snap the NEW battery into place.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,161 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 한 개
I'm a tech savvy user but, I just read this just to be sure there wasn't anything I was missing. I didn't think of grounding the system board for some reason. Thanks for that! Critical step!
David D - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 15
30일 전: 43
전체 시간: 3,105
