주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3567 Memory Module Replacement
  1. Dell Inspiron 15 3567 Memory Module Replacement, Popping up the Memory Module: 1 단계, 이미지 1/1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Compter.
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3567 Memory Module Replacement, Sliding the Memory Module: 2 단계, 이미지 1/1
    • Slide and remove the memory module from the memory-module slot
  3. Dell Inspiron 15 3567 Memory Module Replacement, Align the Notch: 3 단계, 이미지 1/1
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  4. Dell Inspiron 15 3567 Memory Module Replacement, Installing the Memory Module: 4 단계, 이미지 1/1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Terrence15
회원 가입일: 12/18/17
79,161 평판
안내서 441개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 32
전체 시간: 2,077
