주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3568 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15 3568 Display Assembly Replacement, Open the Display: 1 단계, 이미지 1개 중 1개
  2. Dell Inspiron 15 3568 Display Assembly Replacement, Note the Antenna Cable: 2 단계, 이미지 1개 중 1개
    • Note the antenna cable routing and remove the antenna cables from its routing guides on the computer base.
  3. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Cable: 3 단계, 이미지 1개 중 1개
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  4. Dell Inspiron 15 3568 Display Assembly Replacement, Remove the Screws: 4 단계, 이미지 1개 중 1개
    • Remove the screws that secure the display hinges to the computer base.
  5. Dell Inspiron 15 3568 Display Assembly Replacement, Lifting the Display Assembly: 5 단계, 이미지 1개 중 1개
    • Carefully lift the display assembly off the computer base.
  6. Dell Inspiron 15 3568 Display Assembly Replacement, Align the Screw Holes: 6 단계, 이미지 1개 중 1개
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  7. Dell Inspiron 15 3568 Display Assembly Replacement, Replace the Screws: 7 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display hinges to the computer base.
  8. Dell Inspiron 15 3568 Display Assembly Replacement, Route the Display Cable: 8 단계, 이미지 1개 중 1개
    • Route the display cable through its routing guides on the computer base.
  9. Dell Inspiron 15 3568 Display Assembly Replacement, Routing the Antenna Cables: 9 단계, 이미지 1개 중 1개
    • Route the antenna cables through its routing guides and slide the antenna cables through the slot on the computer base.
    • Close the display and turn the computer over.
결승점
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 625
