주요 콘텐츠로 건너뛰기
Dell Inspiron 15 3593 Battery Replacement
필요한 것
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 15 3593 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15 3593 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 15 3593 Battery Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 15 3593 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 3593 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery out carefully and put the new battery in.
결론
Reassemble the computer by following
the above steps in reversed order.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Abdul Obaid
회원 가입일: 01/13/22
169 평판
안내서 1개를 작성함
댓글 2개
not all of the steps
there is somethings missing
aaaa2020 - 답글
So where is the rest of the story?
Jeanette Martinez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 100
전체 시간: 3,463
