주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5502 Case Removal
필요한 것
    • Save and close all open files and exit all open applications.
    • Shut down your computer. Click Start > Shut down.
    • Disconnect your computer and all attached devices from their electrical outlets.
    • Disconnect all attached network devices and peripherals, such as keyboard, mouse, and monitor from your computer.
  1. Dell Inspiron 15 5502 Case Removal, Screws: 2 단계, 이미지 1개 중 1개
    • In the back there are 9 screws.
    • (captive) M2x7.5
    • M2x4
    • Unscrew these and store in a safe place. (eg: nescafe cup, container )
  2. Dell Inspiron 15 5502 Case Removal, Getting the base cover out: 3 단계, 이미지 1개 중 1개
    • Using a plastic scribe, pry the base cover starting from the recess at the display hinge and work your way around the sides to remove the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Dell Inspiron 15 5502 Case Removal, Battery disconecting: 5 단계, 이미지 2개 중 1개 Dell Inspiron 15 5502 Case Removal, Battery disconecting: 5 단계, 이미지 2개 중 2개
    • The sticker and the cable connector(below the sticker)
    • Peel the tape and disconnect the battery cable from the system board.
  4. Dell Inspiron 15 5502 Case Removal, Drain the power: 6 단계, 이미지 1개 중 1개
    • Press and hold the power button for five seconds to ground the computer and drain the flea power.
결론
If you were following another article and was said to follow this guide, now you can go and follow it/continue in the step you stopped!
작성자
1다른 기여자 명과 함께
Kind-hearted, spirited Man
회원 가입일: 08/15/21
1,052 평판
안내서 4개를 작성함
Android Alliance Android Alliance 회원
Community
92 회원들
안내서 734개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 21
전체 시간: 1,476
