주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5565 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 1개 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 2개 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 3개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Lift the latch and using the pull tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5565 Hard Drive Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  3. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
  4. Dell Inspiron 15 5565 Hard Drive Replacement, Disconnecting the Interposer: 4 단계, 이미지 2개 중 1개 Dell Inspiron 15 5565 Hard Drive Replacement, Disconnecting the Interposer: 4 단계, 이미지 2개 중 2개
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 15 5565 Hard Drive Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15 5565 Hard Drive Replacement, Lifting the Hard Drive: 6 단계, 이미지 2개 중 2개
    • Lift the hard drive off the hard-drive bracket.
  7. Dell Inspiron 15 5565 Hard Drive Replacement, Align the Screw Holes: 7 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 15 5565 Hard Drive Replacement, Replace the Screws: 8 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 15 5565 Hard Drive Replacement, Connecting the Interposer: 9 단계, 이미지 1개 중 1개
    • Connect the interposer to the hard-drive assembly.
  10. Dell Inspiron 15 5565 Hard Drive Replacement, Align the Screw Holes: 10 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  11. Dell Inspiron 15 5565 Hard Drive Replacement, Replace the Screws: 11 단계, 이미지 1개 중 1개
    • Replace the screws that secure the hard-drive assembly to the palm rest and keyboard assembly.
  12. Dell Inspiron 15 5565 Hard Drive Replacement, Connect the Hard Drive Cable: 12 단계, 이미지 1개 중 1개
    • Connect the hard-drive cable to the system board and close the latch to secure the cable.
결승점
작성자
2다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,522 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 1,877
