주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5566 Display Assembly Replacement
필요한 것
  1. Dell Inspiron 15 5566 Display Assembly Replacement, Note the Antenna Cable: 1 단계, 이미지 1개 중 1개
  2. Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Latch: 2 단계, 이미지 2개 중 1개 Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Latch: 2 단계, 이미지 2개 중 2개
    • Lift the latch and disconnect the display cable from the system board.
  3. Dell Inspiron 15 5566 Display Assembly Replacement, Note the Display Cable: 3 단계, 이미지 1개 중 1개
    • Note the display cable routing and remove the cable from its routing guides.
  4. Dell Inspiron 15 5566 Display Assembly Replacement, Open the Display: 4 단계, 이미지 1개 중 1개
    • Turn the computer over.
    • Open the display at an angle of 90 degrees.
  5. Dell Inspiron 15 5566 Display Assembly Replacement, Placing the Display: 5 단계, 이미지 1개 중 1개
    • Place the computer on the edge of the table so that the palm-rest assembly is on the table and the display assembly extends past the table edge with the display hinges facing up.
  6. Dell Inspiron 15 5566 Display Assembly Replacement, Remove the Screws: 6 단계, 이미지 1개 중 1개
    • Remove the four screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  7. Dell Inspiron 15 5566 Display Assembly Replacement, Lifting the Display Assembly: 7 단계, 이미지 1개 중 1개
    • Lift the display assembly off the palm-rest assembly.
  8. Dell Inspiron 15 5566 Display Assembly Replacement, Placing the Palm Rest: 8 단계, 이미지 1개 중 1개
    • Place the palm-rest assembly at the edge of the table with the coin-cell battery facing away from the edge.
  9. Dell Inspiron 15 5566 Display Assembly Replacement, Align the Screw Holes: 9 단계, 이미지 1개 중 1개
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
  10. Dell Inspiron 15 5566 Display Assembly Replacement, Replace the Screws: 10 단계, 이미지 1개 중 1개
    • Replace the screws that secure the display hinges to the palm-rest assembly.
    • Close the display and turn the computer over.
  11. Dell Inspiron 15 5566 Display Assembly Replacement, Routing the Display Cable: 12 단계, 이미지 1개 중 1개
    • Route the display cable through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 15 5566 Display Assembly Replacement, Sliding the Display Cable: 13 단계, 이미지 1개 중 1개
    • Slide the display cable to the connector and press down on the latch to connect the display cable to the system board.
  13. Dell Inspiron 15 5566 Display Assembly Replacement, Routing the Antenna Cable: 14 단계, 이미지 1개 중 1개
    • Route the antenna cable through the routing guides on the palm-rest assembly.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 11
전체 시간: 1,914
