주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5566 Memory Modules Replacement
필요한 것
  1. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 1개 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 2개 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Latch: 1 단계, 이미지 3개 중 3개
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Lift the latch and using the pull tab disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 15 5566 Memory Modules Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Assembly: 3 단계, 이미지 1개 중 1개
    • Lift the hard-drive assembly out of the computer base using the hard-drive pull tab.
  4. Dell Inspiron 15 5566 Memory Modules Replacement, Disconnecting the Interposer: 4 단계, 이미지 1개 중 1개
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 15 5566 Memory Modules Replacement, Remove the Screws: 5 단계, 이미지 1개 중 1개
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Bracket: 6 단계, 이미지 2개 중 1개 Dell Inspiron 15 5566 Memory Modules Replacement, Lifting the Hard Drive Bracket: 6 단계, 이미지 2개 중 2개
    • Lift the hard-drive bracket out of the hard drive.
  7. Dell Inspiron 15 5566 Memory Modules Replacement, Placing the Hard Drive Bracket: 7 단계, 이미지 1개 중 1개
    • Place the hard-drive bracket on the NEW hard drive.
  8. Dell Inspiron 15 5566 Memory Modules Replacement, Align the Screw Holes: 8 단계, 이미지 1개 중 1개
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 15 5566 Memory Modules Replacement, Replace the Screws: 9 단계, 이미지 1개 중 1개
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 15 5566 Memory Modules Replacement, Connect the Interposer: 10 단계, 이미지 1개 중 1개
    • Connect the interposer to the hard drive.
  11. Dell Inspiron 15 5566 Memory Modules Replacement, Placing the Hard Drive Assembly: 11 단계, 이미지 1개 중 1개
    • Place the hard-drive assembly in the computer base and align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 15 5566 Memory Modules Replacement, Replace the Screws: 12 단계, 이미지 1개 중 1개
    • Replace the four screws (M2.5x8) that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 15 5566 Memory Modules Replacement, Sliding the Hard Drive Cable: 13 단계, 이미지 1개 중 1개
    • Slide the hard-drive cable into the connector and press down on the latch to secure the cable to the system board.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,555 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,548
