주요 콘텐츠로 건너뛰기
Dell Inspiron 15 5576 Gaming Battery Replacement
필요한 것
  1. Dell Inspiron 15 5576 Gaming Battery Replacement, Remove the Battery Cable: 1 단계, 이미지 1개 중 1개
  2. Dell Inspiron 15 5576 Gaming Battery Replacement, Remove the Screws: 2 단계, 이미지 1개 중 1개
    • Remove the five screws (M2x5 T8) that secure the battery to the computer base.
  3. Dell Inspiron 15 5576 Gaming Battery Replacement, Lifting the Battery: 3 단계, 이미지 2개 중 1개 Dell Inspiron 15 5576 Gaming Battery Replacement, Lifting the Battery: 3 단계, 이미지 2개 중 2개
    • Using the pull tab, lift the battery, along with its cable, off the computer base.
    • Turn the computer over, open the display, and press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 15 5576 Gaming Battery Replacement, Sliding the Battery: 5 단계, 이미지 1개 중 1개
    • Slide the NEW battery in the slot on the computer base.
  5. Dell Inspiron 15 5576 Gaming Battery Replacement, Align the Screw Holes: 6 단계, 이미지 1개 중 1개
    • Align the screw holes on the battery with the screw holes on the computer base.
  6. Dell Inspiron 15 5576 Gaming Battery Replacement, Replace the Screws: 7 단계, 이미지 1개 중 1개
    • Replace the five screws (M2x5 T8) that secure the battery to the computer base.
  7. Dell Inspiron 15 5576 Gaming Battery Replacement, Routing the Battery Cable: 8 단계, 이미지 1개 중 1개
    • Route the battery cable through the routing guides on the computer base.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Terrence15
회원 가입일: 12/18/17
79,858 평판
안내서 441개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,994개를 작성함
2가이드 댓글
the only instruction missing is how to tale the back off. if that was included it would be great
lizziemc12 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 922
